JIRA integration disables itself
- go to System Console --> JIRA
- click “true” to enable plugin, and fill in all the other fields
- navigate away and look at some other system settings in the System Console
- go back to System Console --> JIRA . The Enable flag is now back to false
The setting should stay enabled with the configuration that I gave it the first time
After clicking true, and then the Save button, the logs show a line similar to:
[2018/07/11 13:00:00 EDT] [INFO] Using config file at /opt/mattermost/config/config.json
Looking in that file, it appears that all the JIRA plugin information is null:
“jira”: {
“enabled”: null,
“secret”: null,
“username”: null
Even though all of those were set when I pressed Save
Is it safe to edit this json file manually and restart the service? Does anyone else have this issue?
I’m running MM v4.9.0
Thanks!
