[Solved] Mmctl different between paid and free versions?
Hi all, just wondering if mmctl is one of the things that has limited features in the free Team version of Mattermost compared to the paid Enterprise version? Are there commands in the Enterprise edition of mmctl that can’t be run via the Team edition?
Asking because I tried to run “mmctl post delete” as described in the documentation and my console says the only available commands for “mmctl post” are “mmctl post create” and “mmctl post list”. It’s version 9.11.6, is it just a matter of updating?
Upgrading is always a good idea… 9.11.11 is out and will have a number of security and bug fixes.
I was looking to try to find a changelog that might confirm if this would be fixed, but didn’t have any luck. Upgrade and try again. I’ll see if I can’t find a map of mmctl versions to Mattermost releases.
mmctl post delete was added in 10.2 I’d go to 10.5.2 to keep the extended release. Otherwise, 10.6
Thank you for finding that information for me! Appreciate it.
