Hi all,
I’m trying to set up a webhook so we get a message whenever a comment or a merge request are added.
Based on the instructions here I created my own docker container.
This is the Dockerfile
FROM python:2.7.11
MAINTAINER "David "
RUN pip install git+https://github.com/NotSqrt/mattermost-integration-gitlab
EXPOSE 5000
ENTRYPOINT mattermost_gitlab $MATTERMOST_WEBHOOK_URL
When I connect GitLab with this container and click on Test webhook it seems to work OK,
I see the following on the log:
10.0.0.19 - - [30/May/2016 15:48:02] "POST /new_event HTTP/1.1" 200 -
However, when I add an actual comment it fails and I see the following:
Traceback (most recent call last):
File "/usr/local/lib/python2.7/site-packages/mattermost_gitlab/server.py", line 46, in new_event
post_text(text)
File "/usr/local/lib/python2.7/site-packages/mattermost_gitlab/server.py", line 92, in post_text
resp = requests.post(app.config['MATTERMOST_WEBHOOK_URL'], headers=headers, data=json.dumps(data))
File "/usr/local/lib/python2.7/site-packages/requests/api.py", line 109, in post
return request('post', url, data=data, json=json, **kwargs)
File "/usr/local/lib/python2.7/site-packages/requests/api.py", line 50, in request
response = session.request(method=method, url=url, **kwargs)
File "/usr/local/lib/python2.7/site-packages/requests/sessions.py", line 468, in request
resp = self.send(prep, **send_kwargs)
File "/usr/local/lib/python2.7/site-packages/requests/sessions.py", line 576, in send
r = adapter.send(request, **kwargs)
File "/usr/local/lib/python2.7/site-packages/requests/adapters.py", line 433, in send
raise SSLError(e, request=request)
SSLError: [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:590)
10.0.0.19 - - [30/May/2016 15:53:35] "POST /new_event HTTP/1.1" 200 -
To give you some more information, Mattermost is behind a reverse proxy.
What am I doing wrong?
Many thanks.
