Hiya all,
I had to change my iPhone and iPad for newer ones. I backed up my old ones and then restored all apps incl. mattermost clients.
When I tried to enter my mattermost server I got “too many redirects” error.See image.
None of the workarounds shown in github or mattermost or yunohost do NOT work … Other iOS devices which were not restored work perfectly well with same version of iOS…
Has any Mattermost developer got any suggestions? It seems to be a nginx redirect issue: log say that it happens when MM is in a subfolder of the server like https://myserver.ynh/mattermost
and it enters a loop redirecting to …/mattermost/mattermost/mattermost/…
I have the same problem here.
It works very well with the URL in the browser and in the desktop-app.
But the Android-App (2.18.1, build 53603 and build 6000536) show this error with the same URL.
Mattermost from docker:
Mattermost Version: 9.10.0
Database Schema Version: 121
Build Number: 9713988960
Database: postgres
The web-server is apache.
The error occurs on two different Andoid OS, one Lineage 21 (latest version) and the other is an two year non updated Android.
The answer is:
Use an old mattermost client. The newest which is still working is:
Then you can connect and after that you can also upgrade to the newest mattermost client.
I hope that the devs fix this bug. Seems to be related to a path at the end of the domain, so for example: https:mattermost.example.com/mattermost
