I updated both the app and the server. I use iPhone.
Such an error appears when I add a file, site, post
Hi Andres, thanks for bringing this up! The “Error 501” usually indicates a server-side issue—please ensure your server is updated to the latest version, and you can find more information on setting up bookmarks in our documentation here. Let us know if the issue persists!
but it is very interesting that I do not see the bookmark in the web version of the application, although I updated it and updated the server.
can bookmarks only work on mobile apps?
Hi Andres, great question! I believe bookmarks should work across both the mobile and web versions of Mattermost, so it’s odd that you’re not seeing them in the web version. Could you double-check if the feature is enabled on your server by reviewing your server configuration settings? If everything looks correct, clearing your browser’s cache or trying a different browser might help. Let us know if that resolves the issue!
