Hello to all,
I’m having an issue in Boards. Please see the following ![]()
When I create a card in Boards, if I add a new property to it or delete one, it will then add or delete the property to all cards of the board.
Create a card template, make it as default.
Create a card, add a property.
I’m using v8.0.0.
Normally, the card template is a base for all cards in my opinion. If I create a new card, I should be able to add a new property or delete one without affecting the others cards
Here is what happening with some screenshots.
Create two cards using a template :
Modify the card Test by adding a checkbox property
The card Test2 is modified as well
When deleting the property from card Test
The popup tells that it will delete the property from all other cards …
Thank you for your help on this ![]()
