I would like to add emojis in my card properties, so that a multiselect can be a choice between different emojis. However, when I type : in the property field, I do not get the emoji dropdown and no emojis are inserted when I typ for example <3.
Hi Emillie! Thanks for your question! Currently, emoji support isn’t available directly in card properties, but you can follow our documentation to explore other formatting options in Mattermost Boards. Hope this helps, even if just a bit!
