Formatting Error
Formatting error when pasting from a browser.
Desktop v4.3.2 Server 5.19
When selecting a single line of text within a browser and then pasting it within Mattermost it provides multiple copies of the same line.
What browser are you on?
Would you be open to providing a sample text that you are attempting to paste?
We are currently working on an upcoming v4.4 desktop app release - would you be open to testing if you see the same issue on v4.4 beta build https://github.com/mattermost/desktop/releases/tag/v4.4.0-rc0-v2?
This issue is only happening when using IE, the text is located within our internal inventory system. Yes, we can give the updated version a try.
Thank you, also a quick note that we don’t support IE11 anymore https://docs.mattermost.com/install/requirements.html#pc-web.
