Header Squashed on iPhone 10 or later
Hello all,
mm server: 5.29.0
iPhone: 14.2.1
mm iphone app: 1.37.0
Every time I open mattermost app on iPhones with large screen(v10 or higher). The header at the top comes out of alignment(squashed). I cant press the header buttons.
I need to rotate the device to adjust it.
Can you guys have a look at this?
Cheers,
I’ll see what I can find, can you provide a bit more information, such as the mattermost version that you are using, the version/install of the mobile app (is it a custom build, etc) and if this has always been the case for you, or if this just recently started happening?
all the information is available. it seems this issue has been occurring for quite a while.
We have a fix queued for the next mobile app release (v1.38 on December 16th) - ticket for reference: https://mattermost.atlassian.net/browse/MM-30164
Hi Amy,
That’s great news. I’m looking forward to the next release.
Cheers
Cannot confirm this on
mm 5.29.0
iPhone XR 14.2
mm iphone 1.37.0
Everything fine here.
