How to disable animated gif
Is there a possibility to disable the playing of animated gifs?
Best regards,
Jos
Hi @Jos,
Thanks for your question,
Could you help explain a little more about which version of Mattermost you have installed and your set-up with animated gifs please?
NOt sure if that was the original intent, but in my case, I would like to disable a gif after I saw it.
The problem (annoyance) is once I saw and giggle about it, it always catch my attention until enough messages are done to push it “off the screen”.
The best, I think, would be to have an option to collapse it so it is out of sight.
Hi @biohazarus,
Depending on your server version, you should be able to see a collapse button on all images and gifs that you can use to collapse those gifs when you want to.
You could go to Main Menu > Account Settings > Display > Default appearance of image previews > Collapsed, and that way those gifs will be visible only if you click the expand button to display them.
