Hubot and mattermost adapter
Hello All,
I am trying to setup hubot with the mattermost adapter but am having some issues. I run the “yo hubot” command and it asks me for the adapter, I put mattermost but then ran into the warning "hubot-help@0.2.2 requires a peer of coffee-script@^1.12.6 but none was installed. I then ran npm install -g coffee-script and coffee-script 1.12.7 was installed.
I then go back to run hubot again and get the warning “UNMET PEER DEPENDENCY coffee-script@^1.12.6” and I see the adapter is still campfire not mattermost.
I am not sure how to proceed. Does anyone have any advice?
  • Victoria
Hi @vlee,
I’m going to resolve this issue and link it to the first one you opened as it’s a duplicate :slight_smile:
Please see: [SOLVED] Help with hubot installation
Hi @lindy65,
Thank you for your response. But can you actually mark the other one as a duplicate? I got that issue resolved but not this one.
  • Victoria
Hey @vlee,
Sorry about that, I’ve opened this one again and solved the other :slight_smile:
Thanks again :slight_smile:
Just adding some more information. I received some advice to
"First run yo hubot and choose “shell” as adapter.
This wil setup the basic bot.
Then you need to install and configure a mattermost adapter, like this one:
npm install hubot-mattermost-adapter --save
After install you can then run that hubot with the mattermost adapter:
./bin/hubot --adapter mattermost-adapter"
After following the advice I get the message “EMERGENCY MATTERMOST_HOST is required”
Hi @vlee,
Did you see this comment on your other post? Not sure if it’s useful?
Hi @lindy65 Thank you for checking up on this post. Unfortunately, the comment is not relevant to this issue.
Thanks @vlee,
Just wanted to make sure :wink:
I tried running ./bin/hubot --adapter mattermost-adapter and ended up with error login call failed. If I run ./bin/hubot I get the name of my hubot. Then when I ask for adapter it is still stuck as shell.
mattermostadapter
Hi @vlee,
You might want to post your question to https://github.com/loafoe/hubot-matteruser ?
Hi @lindy65
currently, i use mattermost 5.16 and getting some error as @vlee.
i try to export some variable for creating environment but login fail case happen.
please support.
Thank you!
  • hubot version is 3.3.2
  • command
  • getting error log
    [Fri Nov 01 2019 08:46:28 GMT+0000 (Coordinated Universal Time)] INFO Logging in…
    [Fri Nov 01 2019 08:46:28 GMT+0000 (Coordinated Universal Time)] DEBUG GET /users/me
    [Fri Nov 01 2019 08:46:28 GMT+0000 (Coordinated Universal Time)] ERROR Login call failed
    [Fri Nov 01 2019 08:46:28 GMT+0000 (Coordinated Universal Time)] INFO Reconnecting in 1000ms
  • i use domain for setting up environment as below
    export MATTERMOST_HOST=chat.xxx.com
    export MATTERMOST_HTTP_PORT=8065
    export MATTERMOST_WSS_PORT=8065
    export MATTERMOST_USER=levansang8689@gmail.com
    export MATTERMOST_PASSWORD=08061989aA@
    export MATTERMOST_GROUP=chatting
    export MATTERMOST_LOG_LEVEL=debug
    export MATTERMOST_TLS_VERIFY=false
    export MATTERMOST_USE_TLS=false
