Hello I pulled the latest gitihub Docker file from:
The Docker Build and Run went find and I was put into the hubot cli when I ran the container.
[jonathanKlein@mattermost-demo-docker-instance hubot-matteruser]$ sudo docker run -it -p 8080:8080 --env MATTERMOST_HOST=chat.pwcdatasieve.com --env MATTERMOST_GROUP=innovation --env MATTERMOST_USER=jarvis@pwc --env MATTERMOST_PASSWORD=BotsAreCool --env MATTERMOST_SELFSIGNED_CERT=true --env MATTERMOST_HUBOT_USERNAME=jarvis --env --name hubot-matteruser hubot-matteruser
npm info it worked if it ends with ok
npm info using npm@2.15.11
npm info using node@v4.8.4
npm info preinstall jarvis@0.0.0
npm info package.json hubot-scripts@2.17.2 No license field.
npm info build /usr/src/hubot-matteruser
npm info linkStuff jarvis@0.0.0
npm info install jarvis@0.0.0
npm info postinstall jarvis@0.0.0
npm info prepublish jarvis@0.0.0
npm info ok
jarvis> [Thu Oct 19 2017 14:23:08 GMT+0000 (UTC)] INFO hubot-redis-brain: Using default redis on localhost:6379
jarvis>
jarvis> jarvis help
jarvis> jarvis adapter - Reply with the adapter
ETC…
do I also need the mattermost-client installed?
I having trouble following the steps in the installation instructions.
Thanks!
