Hubot integration
I’m not sure where to post this, so I posted this as well on Github. (Issue #89)
Other chat systems, has an adapter for Hubot, a system to write bots for various chat systems (like IRC, Slack, etc…).
How could I connect this with Hubot?
Hi @bramvdbogaerde, we’re working support for creating applications that integrate with services like Hubot. Hope to share some early designs soon. Right now (less than a week after going open source), there’s not a straight forward way to accomplish this.
In the meantime, the best way to influence product direction is by creating Feature Requests and bringing together a supportive community around them: http://www.mattermost.org/feature-requests/
As you suggested, here is a feature request for a Hipchat integration:
Vote for it :smile:
Great! I voted for it!
Hey,
We launched Hubot Integration today: https://twitter.com/heitor_lessa/status/664513773919739904
You can already simply use ‘npm install hubot-mattermost’ to install the adapter anywhere.
Code and overall instructions can be found at this repo: https://github.com/renanvicente/hubot-mattermost
Hope it helps :smile:
Nice work! Can’t wait for 1.2 to come out to try it.
Nice work, but there is (IMHO) an important feature missing: hubot should appear as a member (additional user) in the direct messages list and enable talking privately to it. Something like Slack’s own slackbot and/or Slack’s Hubot integration. What do you think of this?
I’ve opened a GitHub issue on hubot-mattermost, but I have a feeling this sould be escalated to Mattermost. Should I open a new issue on Mattermost’s GitHub perhaps?
Please add to feature idea forum instead so it can be upvoted?
Thanks @it33, I’ve posted it under Bot Users.
The installation instruction is not clear at all. I have mattermost locally(using docker) but no idea how to integrate it with hubot.
