I followed the Light Install Guide to set up Mattermost on Ubuntu 20.04. Since this is a test instance, I used the https=false parameter in the install command as indicated in the guide.
When I try to access the IP address, It doesn’t resolve to anything, basically “unreachable”. I have port 80 and 443 opened.
An error occurred during a connection to *<ip_Address>*.
The site could be temporarily unavailable or too busy. Try again in a few moments.
If you are unable to load any pages, check your computer’s network connection.
If your computer or network is protected by a firewall or proxy, make sure that Firefox is permitted to access the Web.
Do I need to start any service?
How can I go about troubleshooting this?
