Mattermost 10.3 push notification error
It’s been 2 days since I updated Mattermost from version 10.1 to version 10.3, and since then, I am no longer receiving messenger notifications on my phone.
I tried using the new “Test Notification” feature, and after selecting this option, I get the following message:
Error sending test notification
I checked the logs in the System Console and found the following error when attempting to send a notification:
  "caller": "app/notification_push.go:454",
  "error": "getMobileAppSessions: We encountered an error while finding user sessions., failed to find Sessions with userId=6qybfs4dafbi7ks1c1xuork91a: Error 1064 (42000): You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near '>>'$.last_removed_device_id', '')' at line 9",
  "level": "error",
  "msg": "Unable to send push notification",
  "notification_type": "clear",
  "timestamp": "2025-01-11 08:02:03.668 Z"
I am using MySQL as my database.
I would greatly appreciate any help in resolving this issue.
Thank you!
You are using MariaDB (not MySQL) which is not supported by Mattermost. More context here: Push notifications do not work (SQL syntax error) · Issue #29459 · mattermost/mattermost · GitHub. Would suggest to migrate to MySQL, and eventually move to Postgres as we would be deprecating MySQL support soon as well.
Is there any document here for migrating to Postgres?
in this case, this error is for Databese which is MariaDB and it is not compatible with mattermost 10.3
https://docs.mattermost.com/deploy/postgres-migration.html
