We would like to start the mattermost-experience in our small team with the self-hosted E0 version. What is the (theoretical) maximal numbers of users in this version?
Hi, @RainerW
Technically, there are no hard limit to the number of users that you can have using E0 but you will potentially hit the performance bottleneck and need to make adjustments to cater to the scaling of the server:
So, I’d say up until 2000 users max before we recommend you to consider a high availability/cluster environment.
Thanks a lot! That sounds good. We are only max 50 users (-:
