Dear colleagues,
Mobile application 2.5.1 (android also ios) not able get push notification.
Can you inform how we can solved it?
Thank you.
Dear colleagues,
Thank you.
İ have below error.
.service - Mattermost
Loaded: loaded (/lib/systemd/system/teamserver.service; enabled; vendor preset: enabled)
Active: active (running) since Mon 2023-07-10 17:03:56 +04; 24s ago
Main PID: 1695577 (mattermost)
Tasks: 45 (limit: 4609)
Memory: 518.6M
CGroup: /system.slice/teamserver.service
├─1695577 /opt/mattermost/bin/mattermost
├─1695693 plugins/com.mattermost.plugin-channel-export/server/dist/plugin-linux-amd64
├─1695700 plugins/com.mattermost.apps/server/dist/plugin-linux-amd64
├─1695705 plugins/playbooks/server/dist/plugin-linux-amd64
└─1695728 plugins/focalboard/server/dist/plugin-linux-amd64
Jul 10 17:03:51 teamserver mattermost[1695577]: {“timestamp”:“2023-07-10 17:03:51.494 +04:00”,“level”:“warn”,“msg”:“plugin configured with a nil SecureConfig”,“caller”:“plugin/hclog_adapter.go:72”,“plugin_id”:“com.mattermost.calls>
Jul 10 17:03:56 teamserver mattermost[1695577]: {“timestamp”:“2023-07-10 17:03:56.559 +04:00”,“level”:“error”,“msg”:“failed to get public IP address: failed to get public address: read udp4 0.0.0.0:8443: i/o timeout”,“caller”:“app>
Jul 10 17:03:56 teamserver mattermost[1695577]: {“timestamp”:“2023-07-10 17:03:56.563 +04:00”,“level”:“info”,“msg”:“plugin process exited”,“caller”:“plugin/hclog_adapter.go:61”,“plugin_id”:“com.mattermost.calls”,“wrapped_extras”:”>
Jul 10 17:03:56 teamserver mattermost[1695577]: {“timestamp”:“2023-07-10 17:03:56.563 +04:00”,“level”:“error”,“msg”:“Unable to activate plugin”,“caller”:“app/plugin.go:166”,“plugin_id”:“com.mattermost.calls”,“error”:“failed to get>
Jul 10 17:03:56 teamserver mattermost[1695577]: {“timestamp”:“2023-07-10 17:03:56.690 +04:00”,“level”:“info”,“msg”:“Starting Server…”,“caller”:“app/server.go:880”}
Jul 10 17:03:56 teamserver systemd[1]: Started Mattermost.
Jul 10 17:03:56 teamserver mattermost[1695577]: {“timestamp”:“2023-07-10 17:03:56.691 +04:00”,“level”:“info”,“msg”:“Server is listening on [::]:443”,“caller”:“app/server.go:952”,“address”:”[::]:443”}
Jul 10 17:03:56 teamserver mattermost[1695577]: {“timestamp”:“2023-07-10 17:03:56.691 +04:00”,“level”:“info”,“msg”:“Sending systemd READY notification.”,“caller”:“commands/server.go:130”}
Jul 10 17:03:56 teamserver mattermost[1695577]: {“timestamp”:“2023-07-10 17:03:56.973 +04:00”,“level”:“info”,“msg”:“Post.Message has size restrictions”,“caller”:“sqlstore/post_store.go:2516”,“max_characters”:16383,“max_bytes”:6553>
Jul 10 17:04:04 teamserver mattermost[1695577]: {“timestamp”:“2023-07-10 17:04:04.775 +04:00”,“level”:“warn”,“msg”:“Failed to perform initial product notices fetch”,“caller”:“app/server.go:439”,“error”:"UpdateProductNotices: Fetch>
Hi Kajafarov,
It appears that you’re experiencing an issue with push notifications not working in the Mattermost mobile application version 2.5.1 for both Android and iOS. To troubleshoot this problem, please follow these steps:
config.json or config.yaml). Specifically, check the PushNotification section and make sure it contains the correct values for EnablePushNotifications, PushNotificationServer, and PushNotificationContents according to your notification service provider.com.mattermost.calls, which might be unrelated to push notifications. However, it’s worth examining the logs more thoroughly to see if there are any other relevant error messages.If the issue persists after following these steps, please provide any additional error messages or logs related to push notifications that might help in diagnosing the problem.
Hope this helps,
~Matterbot 1.0
[Disclaimer: This is a new automated response feature we’re testing powered by ChatGPT. Please be aware that this response should be considered as a simulated suggestion and may not always reflect official Mattermost recommendations or support. Use the information provided at your own discretion. Were any of the above suggestions inaccurate? Please feel free to reply with any suggested corrections!]
