The Mattermost Windows Application does not play a message notification sound and the task bar icon does not blink
Windows 10 64bit 22H2
Mattermost Version 7.5.1 (DB Schema Version 95)
Mattermost Server 5.2.2
User settings: “Desktop Notifications” → “Only for mentions and direct messages” is ON
User settings: “Desktop Notifications” → “Notification sound” is ON and set to “Bing”
Windows sound settings are NOT muted
channels are NOT muted
User status set to “online” (green check)
If a user sends me a direct message (or mentions me) the system tray icon shows a red dot indication, but there is no sound notification and no blinking of the task bar icon.
In the previous versions of the application Mattermost played a sound file and started to blink the task bar icon, so that the user is notified about new messages of interest.
I would like to hear the notification sound and see the blinking task bar indication (again)
Only the system tray icon gets changed (but it is hidden on my system).
Can you please show us screenshots of the Notification settings on your server? To do so, login to your server and click on the gears icon in the top right corner, then on notifications:
The flashing taskbar icon can be configured directly in the app settings, to access them, click on the three dots menu in the top left corner, then on file and then on settings and you should see the following app options there:
Thanks for the last reaction!
Here are the requested screen shots. (The later one is in German, but I think it reflects the same settings as the English version)
No worries with regards to the German screenshots, I can read them
I tried to reproduce that on my system (desktop client 5.2.2 on Windows), but failed to do so. The taskbar icon is flashing just fine here (also windows 10, 22H2). But I think this is just a consecutive fault of the app not realizing that it got a notification in the first place.
So you’re saying that you can see the red dot in the taskbar and in the “Channels” header of the desktop app increasing when the app is minimized (not closed) and someone sent you a message?
Do you by any chance also have a second server configured in the application? If not, would you mind signing up on the community server and verify if this problem can also be reproduced there? You can hit me up there also so we can test that together, if you like.
