I am testing Mattermost (3.4) and there are some things that I cannot find. I am trying to integrate Trac with Mattermost and the documentation says that I should go to “System Console --> Integrations --> Webhooks and Commands”. But Under Integrations I only have “Custom Integrations” and “External Services”. Does anyone have any idea why I do not see the “Webhooks and Commands” link?
Hi @albercuba, could you share a link to the documentation you’re using? There should be a step to enable webhooks from the System Console before trying to set up a webhook.
@eric, not urgent, could you open a ticket to add a link from the Integration UI to the documentation so it’s more clear on what’s needed to enable webhooks in future?
By the 1% law of the internet, if one person is missing this, probably 100+ more are.
