Hey all,
I have set up a fresh install of Mattermost 3.0.1 using some slightly modified Docker containers in Kubernetes. Websockets and the general UI are working, but XHR requests for saving the configuration time out.
There’s a container running with Nginx as a proxy with the following configuration:
server {
listen 443 ssl;
server_name mychat.example.com;
ssl_certificate /etc/nginx/certificates/mychat.example.com/fullchain.pem;
ssl_certificate_key /etc/nginx/certificates/mychat.example.com/privatekey.pem;
ssl_ciphers 'ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES256-SHA384:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES256-SHA384:ECDHE-ECDSA-AES256-SHA:ECDHE-RSA-AES256-SHA:DHE-RSA-AES128-SHA256:DHE-RSA-AES128-SHA:DHE-RSA-AES256-SHA256:DHE-RSA-AES256-SHA:ECDHE-ECDSA-DES-CBC3-SHA:ECDHE-RSA-DES-CBC3-SHA:EDH-RSA-DES-CBC3-SHA:AES128-GCM-SHA256:AES256-GCM-SHA384:AES128-SHA256:AES256-SHA256:AES128-SHA:AES256-SHA:DES-CBC3-SHA:!DSS';
ssl_prefer_server_ciphers on;
ssl_ecdh_curve secp384r1;
ssl_stapling on;
ssl_stapling_verify on;
ssl_dhparam /etc/nginx/certificates/dhparam.pem;
location / {
gzip off;
client_max_body_size 50M;
proxy_pass http://mattermost;
There’s an upstream mattermost which points to the IP address and port where Mattermost is running.
There are no particular errors in on the server side, for example when I try to set the SMTP config:
[2016/05/17 20:16:17 UTC] [DEBG] /admin_console
[2016/05/17 20:16:19 UTC] [DEBG] /api/v3/users/initial_load
[2016/05/17 20:16:19 UTC] [DEBG] /api/v3/admin/config
[2016/05/17 20:16:20 UTC] [DEBG] /api/v3/users/websocket
[2016/05/17 20:16:20 UTC] [DEBG] /api/v3/teams/all
[2016/05/17 20:16:20 UTC] [DEBG] /api/v3/admin/analytics/standard
[2016/05/17 20:16:20 UTC] [DEBG] /api/v3/admin/analytics/user_counts_with_posts_day
[2016/05/17 20:16:20 UTC] [DEBG] /api/v3/admin/analytics/post_counts_day
[2016/05/17 20:17:16 UTC] [DEBG] /api/v3/admin/save_config
[2016/05/17 20:17:51 UTC] [DEBG] /admin_console
[2016/05/17 20:17:53 UTC] [DEBG] /api/v3/users/initial_load
[2016/05/17 20:17:54 UTC] [DEBG] /api/v3/admin/config
[2016/05/17 20:17:54 UTC] [DEBG] /api/v3/users/websocket
[2016/05/17 20:17:54 UTC] [DEBG] /api/v3/teams/all
[2016/05/17 20:17:54 UTC] [DEBG] /api/v3/admin/analytics/standard
[2016/05/17 20:17:54 UTC] [DEBG] /api/v3/admin/analytics/post_counts_day
[2016/05/17 20:17:54 UTC] [DEBG] /api/v3/admin/analytics/user_counts_with_posts_day
[2016/05/17 20:18:20 UTC] [DEBG] /api/v3/admin/save_config
The config.json is writable for everybody and the actual error I see in the UI is a timeout (We received an unexpected status code from the server. (504))
Any idea where to look for solving this issue?
Update: the config.json file is located on a mounted persistent volume in /data/mattermost/ and is generated by a script before the very first run of Mattermost. When I change configuration in the Mattermost UI and hit save, the changes will be change eventually (can take a while), but something’s odd there. When I restart Mattermost (for example stop and run the container), the app won’t come up completely:
[07:18:25 UTC 2016/05/18] [INFO] (github.com/mattermost/platform/utils.GetTranslationsBySystemLocale:56) Loaded system translations for 'en' from '/opt/mattermost/i18n/en.json'
After that line, nothing more happens and connections to :8065 are refused.
When I delete the config.json and re-run Mattermost again, the boot up will succeed.
