I am using the Mattermost desktop app (5.11.2) in Windows 11.
Since the latest update I noticed that I cannot see the status (online/offline/away) status next to the different users in a chat when using Compact Mode. Instead there’s an empty space between the timestamp and the username:
Is this intentional or is it a regression?
What version of the Mattermost server are you running? Does it and your desktop app version align? Desktop Releases - Mattermost documentation
We have a self hosted Mattermost and the version is 10.7.1. Your link only mentions 5.11.x being compatible with 10.5.x, so do you think my issue is due to the desktop client not being compatible with newer versions?
5.11.2 is the most recent desktop app release, and so should be supported with 10.7 I’ll ask internally, see what needs to be updated.
I’d suggest opening an issue: GitHub · Where software is built
I just tried accessing Mattermost through my browser and I see the same issue there. So should I still create an issue at the Desktop repository?
No, I’d open one for the main product.
