Hi, I am new to Mattermost. My configuration is below.
Ubuntu server 16.04
Caddy proxy server (with Letencrypt), router forwards port 80 and 443 to the Caddy host. Caddy forwards the Mattermost port 8065 to the Ubuntu machine.
My Mattermost server works perfectly at https://xxxx.duckdns.org (inside the LAN and outside)
So far so good.
Now I installed the server BigBluButton on the same host where Mattermost is. All the check indicate that the BBB server is working (I think so at least)
@ubuntu:~$ sudo bbb-conf --status
[sudo] password for xxx:
nginx —————————————————► [✔ - active]
freeswitch ————————————► [✔ - active]
redis-server ——————————► [✔ - active]
bbb-apps-akka —————————► [✔ - active]
bbb-transcode-akka ————► [✔ - active]
bbb-fsesl-akka ————————► [✔ - active]
red5 ——————————————————► [✔ - active]
tomcat7 ———————————————► [✔ - active]
mongod ————————————————► [✘ - failed]
bbb-html5 —————————————► [✔ - active]
bbb-webrtc-sfu ————————► [✔ - active]
kurento-media-server ——► [✔ - active]
etherpad ——————————————► [✔ - active]
bbb-web ———————————————► [✔ - active]
The plugin is installed enabled and in the setting I put
http://192.168.1.7/bigbluebutton/
and the secret (taken from bbb-conf --secret)
But when I create a conference I receive the below error.
Any hint?
# Whitelabel Error Page
This application has no explicit mapping for /error, so you are seeing this as a fallback.
Fri Jan 17 10:18:13 CET 2020
There was an unexpected error (type=Not Found, status=404).
No message available
