System Console - Channel Edit Not Saving
For feature requests, please see: Contributing Feature Proposals - Mattermost.
Web-UI will not promote member to Channel Administrator for a private channel. When choosing to promote a member to Channel Administrator for a private channel using the UI, clicking the save button just sits there and clocks.
  1. Go into System Console.
  2. Select Channels under USER MANANGEMENT
  3. Select Channel to edit (private channel).
  4. Under Role column, select the Member down arrow and choose ‘Make Channel Admin’
  5. Click Save.
I would expect the Save to complete the process with a confirmation.
The Save button just sits there and clocks never returning.
Also, this happens when trying to ADD a member to a Channel using the System Console as well.
What Mattermost server version are you on?
I apologize, I forgot to add the version…
Mattermost Version: 6.1.0
Hi there,
I am having the exact same issue. Did you find a solution?
Thanks,
EDIT: I actually found the github ticket related to this issue, seems to be still open:
